WREKS
- Port Saint Lucie, Florida
- SX
@Sdrolet You could take the top of the oil cooler off and check the strainer (part [HASH=4116]#7)[/HASH]. That can be done without removing the engine. I would even reuse the rubber o-rings. They can be spot permatexed, if need be, to reassemble.
I’ve not got back to it yet but will post a pic when I’ve got it out. Would you recommend replacing it regardless? Do you think it could have attributed to it?@Sdrolet What was the condition of the rubber coupling connecting the driveshafts?
I have not, I was hoping to avoid that. I’m just an IT guy with some mechanical background and garage monkey. I do t have the means to pull the motor. Is it necessary to get the reduction gear box out? I won’t really have time to get back to it until the weekend.It looks like you are already past that point. The engine is out of the boat, correct?
As soon as I pulled off the oil pump there were all those pieces in where the screen goes, which the screen itself was missing entirely. One of the pieces is the oil pump reduction shaft at the top where it’s slotted. The hardened steel piece. The other pieces are aluminum. So I’m guessing the bearing went maybe and that threw everything out of alignment. I’ve still not got back to working on it. Probably not till the weekend but will post updates and findings.Sorry, @Sdrolet, I am confused. What am I looking at in Post 44. I did not think one could get to the reduction gearbox without pulling the motor.
