Just picked up a 2005 SX230 - oil light on I think
Yesterday after a huge wave of thunderstorms hit Northwood NH.
I own a 2005 and I just read through your posts on the repair. Great work!
We have the same color and love the boat. We get compliments all the time. These are nice looking boats!
Hello, I have the same exact issue on a 2006 SX230. Have replaced the oil pressure sensor (technically its just a switch according to the manual) I've replaced the air filter, performed and oil and filter change and still runs perfect until it literally hits 5,000rpm exactly. Shut the engine off, light goes away. Start the engine, get up to 5,000rpm and boom, light comes on engine throttles down. Does anyone have a definitive resolution for this?
I also have bought the Yamaha diagnostics software and ECM adapter. Cleared the code, which was nothing informative other than Oil Pressure low.
Should I replace the oil pump at this point or test the oil pressure at or around 5,00rpm?
Thanks in advance,
Scott
Hi Scott,
I'm having problems with my oil warning light coming on intermittently on my 2007 SX230. The light comes on randomly sometimes on the port and then sometimes on the starboard. The lights generally only appear when I first start the boat (not every time however) and doesn't happen at high RPM's.
When the lights come on I turn the engines off, let them sit for a minute or so and then start the engines again. If the light doesn't reappear i can speed up and the engines will run at high speed without a problem.
I've purchased two new oil pressure sensors and have looked at the parts diagram for general location however it seems the area is quite congested with wiring looms etc. You said that you changed your sensors, can you please let me know how you did it and any other helpful hints, photos etc.
Your help would be greatly appreciated.
I'm in Australia so there is a bit of a time difference.
Thanks in advance,
Cheers,
Chris
