- Royal, AR
- SX
We often boat until after dark and recover the boat at dark ramps.
We added waterproof LED strip lighting to the frame rails of the trailer so that alignment of the trailer would be visible through the water. They work great and improve visibility on the highway as well.
Although I am curious how our LE members feel about the extra lights on the trailer. I believe this is legal. If not I will add switches to turn them on at the ramp.
Total cost was $27 and about 30 minutes. The supplies consisted of two of these LED Strips, 12 x 18" outdoor wire ties, less than 10' of 16 gauge dual conductor wire and solder and shrink tube that I already had on hand.
@Rana applied the light strips to frame rails starting at the back. I pulled out the front running lights and soldered and shrink tubed 16 gauge wire to the factory wiring. Then I soldered and shrink tubed my 16 gauge wires to the LED strips. And finally we put 6 wire ties around each LED strip and wire. We did the same on both sides.
