Lateral Thruster install on e series.
tabbibus
Lake Lanier, GA
Finally getting around to is installing the LTs! I have a 242 e series. In the install video @JetBoatPilot says to move the throttle up to get the buckets out of the way. Problem is, my buckets don’t move when the boat is off due to the whole e throttles thing. Anyone here dealt with this? Will, any words of wisdom?
BigAbe75
Litchfield, IL
Have to use the override under the black box on the floor in the helm compartment.
tabbibus
Lake Lanier, GA
I know the box. I have no idea how to use it.
BigAbe75
Litchfield, IL
Chief
Lake of the Ozarks, Missouri
242 Limited E-Series
I installed lateral thrusters on my e-series. I dont remember needing to move the buckets. They installed very easily.
afdouble
Upstate, South Carolina
Same here. I have a 2017 E-Series and installed them rather quickly. I don't remember any issues with the buckets. I can't exactly remember, but I think I did move the buckets and they moved with the throttle.
tabbibus
Lake Lanier, GA
well, so I got to the boat only to find that I forgot the keys... try again tomorrow I guess.
Beachbummer
Houston TX
No harm in making some key copies and hiding them on the boat really well, so if you are ever in that position again, you can still go out.
biffdotorg
Pelican Rapids, MN
Am I missing something here? The suggestion was to move them to get them out of the way, but if you look at the install, it's not a necessity.
The buckets on the E-series connect the same as all the rest right? Just disconnect the connector at the bucket, lift the bucket and shove a 2x4 or pool noodle in the pump. No keys needed to do that.
You may be overthinking this install. As I think I installed mine in minutes by flashlight in the driveway.
Good luck,
tdonoughue
The Woodlands, TX 77381
A little OT (apologies), but I got myself a little toolbag from Lowes and made it my boat bag. Keys hang on the handle. Put a tow strap, handheld VHF and inverter inside (along with anything needing to 'go to the boat') and carry it with me in the truck. When I go to the boat, I just make sure I have the bag. Harder to forget for me.
Now, back to your regularly-scheduled program.
