Bill D
- Prairieville, LA
- Limited S
So this spring when I tried to empty the antifreeze out of the shower I noticed I was getting some water in the starboard storage compartment where the pump and tank are located. I assumed that the pump was leaking, but upon inspection it appears that the leak is coming from the bulkhead fitting between the compartment and the area under the swim platform. (See attached picture part #23 or maybe 17) When I looked up the part, it's a ludicrous $70.
The area where this part is located is terribly inaccessible. It's behind the shower tank, nearly completely out of reach. Since it is so inconvenient, I have not done any disassembly/troubleshooting.
Should I order the part, or is this likely something that I can find a non-oem replacement for, like pvc plumbing parts?
So that back wall comes out like most of the other bulkheads throughout the gunnels?
