LED Courtesy Light replacement
atompa
Michigan
good morning everyone and HAPPY SPRING!!!
I'm looking to swap out my factory courtesy light bulbs (1044-99) for and LED equivalent. I've seen it discussed many times on this forum but can't find a part number, any ideas? Going with blue.
Thanks!
My AR210 used a 1044 bulb. I replaced it with a bulb I found online. It was called a 31mm 3528 festoon bulb. It works fine. And it's a lot brighter than the original!
How did you open the housing to replace the bulb?
Mine looks like it’s sealed.
