212s
- 1000 Islands
- 212S
It's not a ground issue if the license plate flashes when you put the the signal on, it's the wrong wiring. You may have the wrong replacement lights? If your stock lights work properly, nothing is wrong with your wiring.
I plan to order the upgrade kit from my local dealer - email Shorland'r with your trailer VIN and they will tell you the part number you need for your lights. There is a kit for my trailer that includes the left/right lights plus the 3-light bar in the center to switch to LED. You may simply have the wrong one that uses a different plug layout.
Also what plug style do you have on your trailer? 7-way blade RV style or 4/5-pin flat connector? The colour codes are different on the 7-way.
