IN2H2O
 - Limited
Hey gang,
I recent purchased a 2008 232 (MR-1 HO motors) and during test drive I noticed the starboard motor was not getting much out the overboard pissers. The boat ran 10,000RPM and 45MPH for a quick test before I realized the starboard motor was not pissing overboard ?. Only ran for a minute or 2, overheat did not come on so hope I'm safe but going to compression test tomorrow. This evening I ran both motors on the hose at idle. The starboard motor did not have any water running out the #19 fitting and very very little coming out the #15. There was a lot of water coming out the pump intake screen and exhaust. Compared to the port motor running on the hose it had a lot coming the #15 fitting and very very little coming out the aft #19 fitting and none at all coming out the bow #19. (Bow #19 was pissing when on the water) Also had water coming out the exhaust and pump intake screen but not nearly as much as the seeming blocked starboard motor. I took a rag and blocked the #15 fitting on both motors and the port motor had more water come out the #19 fitting but the starboard again did not have any.
I confirmed the aft #19 to #15 fitters were not clogged by taking a air gun and blowing though the line. Both lines had the same air pressure exiting. I wanted to pull the #17 fitting but i could not locate it for the life of me but i feel like. Any advise on what else I can check to locate a clog? Anyone know why no water came out the #19 pisser on the hose vs on the water? I ran on the hose at high pressure for several minutes and even at elevated idle RPM's for 30 seconds or so with out luck
