  • Announcing the 2020 Jetboat Pilot SEADEK Group Buy for JetBoaters.net members only! This is your best time to buy Seadek from JetboatPilot - you won't get a better price - the discount has now reached the maximum 30% already!
    So if you are tired of stepping on really hot snaps/carpet, or tired of that musty carpet smell - Seadeck is the best alternative out there! Get in on this now, or pay more later!
    You only have until Wednesday September 30th to get in on this.....So Hurry!
LS2000 Melted Piston
jkorotki
LS
Hello all! I melted the #3 piston on my starboard engine. Pretty obvious that it went lean and poof! As I get ready to rebuild the upper half I am curious if anyone has seen this or could suggest some common causes for this to happen. I do not believe it was an oil issue as I am able to watch oil flow directly into the carb. Any help, guidance, and suggestions would be greatly appreciated.
tdonoughue
The Woodlands, TX 77381
Only help I can offer is to Google melted piston. Seems like a common enough thing on auto engines that they do have some suggested causes. Unfortunately, the causes also seem to be all over the map (bad fuel mix, clogged exhaust, bad injector, etc.).
4x15mph
Downingtown, PA
Probably an air leak causing it to run lean. I wouldn’t just put a new piston and top end without continuing to figure out the problem. I would also recommend doing a leak down test once you have it back together. Good luck
the MfM
LS
I’d check the rear main (crank) seal
