paratrooper39
- San Diego, CA
It most likely will be sufficient, but you may want to have some handy just in case. The cone will not take more than 2-3 oz.@swatski I do not have grease, Jerry said that I could just swap over the existing grease from the OEM cone... unless of course you wanna ship me some
I would get a new OEM impeller, would not bother with anything else. If will be better and less expensive actually.Ok so I have received and installed the new cone, which as promised was extremely easy. I would say the entire deal took me about 20 min or so. I was only able to test the boat with a couple a people in it and there was no tubing as the water was just too busy, however I can say a few things. 1- the boat did seem to pull a bit harder but more importantly it was much more reactive in turns. Again, I'm not sure how much of a difference it will make when a tube is pulling pulled but I am excited to see. 2- I do believe that the overall cavitation was reduced, however when viewing my impeller I suspect I've found the bigger issue, which likely is keeping me from being blown away by the cone. I have to guess that the nice little wave in my impeller isn't helping matters at all. So now I have to figure out that situation and move forward from there.
What kind of grease is needed?Got my cone in today. Waiting on the grease before I start the install. Man, these things are smaller than I thought. They look bigger in other pictures. I can already hear it, "Thats what she said".
I know this is an old post, but do you have an update on how this cone performed? I have the same boat with the same concerns when pulling a tuber. I am wondering if this helped at all.Got my cone in today. Waiting on the grease before I start the install. Man, these things are smaller than I thought. They look bigger in other pictures. I can already hear it, "Thats what she said".
I have a 2017 AR 195 and the Lucky 13 is a game changer. The Lucky 13 with all three spacers has no impact on overall top speed and damn near eliminates all cavitation especially while loaded down with ballast or people.Anyone else running the Lucky 13? I have a good amount of cavitation with 6 adults and 2 kids when wakeboarding. Cavatation normally only occurs when starting from a stand still.
