Michael-Nash
Around 7700 or 7800. Same impeller.What were you top RPM before? Same impeller?
That makes sense, loosing about 200-300 RPM on top with the L13 is typical.Around 7700 or 7800. Same impeller.
That’s crazy it should be the exact opposite.Went out on the water today to test out the cone. With all 3 spacers I'm at around 7600 rpm and top speed around 37 mph. When I removed all the spacers it took me down to 7500 with a top speed of 35.
Not sure why I'm experiencing a loss in top speed as I used to be able to run 40-42 WOT with a stock cone, ribbon delete and no fins. That was also prior to my 10 hour service (changed oil and filter, added grease to housing). I checked the oil level and I'm right between the high-low marks and I put the right amount of grease in the housing. Any thoughts on what is killing my top speed?
Very informative writeup! I have had similar experience with both mods, CObras made we want to pull skiers and boarders, and the L13 was dynamite, I think I posted vids of the difference it was remarkable in the 190.I finally got a chance tonight to take a test ride since installing the Lucky 13 cone and cobra ultimate ak-19 fins. First the Cobra fins...I’m a very happy customer. The boat handled so much better it made me smile. At WOT it was extremely responsive and, yes I’ll say it, very fun to drive. I didn’t notice a heavy steering feel as others have reported. Rather it felt more like a tight sports car feel with very quick response. At slow speed I had no issue with delayed steering response both forward and reverse. I can’t speak for any other reviews or how the fins worked with their setup, but as for me and mine...definitely worth the investment. I’m not trying to sell anyone on anything, nor do I have experience with any other fins as a comparison. Just giving an honest review of how they perform for me compared to stock. Now the Lucky 13 cone. I have it installed with all three washers. I must say honestly I had no real issue with cavitation on the hole shot so I didn’t notice much difference there. My main reason for installing it was because I hated how the speed bled off in sharp cornering whether towing or not. Especially didn’t like it though towing a tube. In full disclosure, I haven’t tested it towing yet but in a run with just me in the boat it fully held its speed in sharp turns with no bleed off...it didn’t do that before the cone install...big smile #2. The combination of the cone and fins together in hard turns was very fun to drive. If it holds the same when towing, my tube riders should get the kind of ride they became accustomed to with my SeaRay from the past few years. I didn’t notice a big difference in RPM’s. Maybe dropped a hundred or so, so nothing concerning. WOT still at around 7600-7700 and top speed relatively unchanged. I don’t do a lot at WOT anyway. Was more looking for low end grunt and control which I believe I accomplished. I’ll get a better feel for consistency when I get more people and other sports activities going, but for the first run, I’m very pleased with the result. Thanks to Jeff from Cobra Steering for your help during install.
Those are great numbers, if you asked me. No cavitation on hard start in a single is not to be taken for granted! Your pump is working great.What's the target RPM to shoot for in these single engine boats? I've been watching mine lately and am consistently maxed out at 7350 (as reported by the digital readout under the tach). Most of the time hanging in the 7250-7300 range. This "feels" low to me as I hear others talking about 7600-7700 range.
Last week with a VERY light load (8yr old and myself, no coolers or gear, bimini stowed) we hit 43mph at 7350rpm, so I feel like the top speed is where it needs to be. Pretty consistent 40mph top speed with bimini deployed and 2-adults, 2kids, coolers, etc. Still get some cavitation on HARD corners though. Running the L13 with all spacers, sealed tunnel (last season), and ribbon delete.
I have also noticed that the boat responds MUCH better in turns if I have some weight in the back of the boat. Couple of adults on the rear bench when tubing earlier this season and the boat was exceptionally "hooked up". Steering was nice and tight, zero cavitation on turns, just a really solid feel to the controls. Normal usages is 8yr old in the bow, adult in drivers seat, and another adult near midship/glove box. This yields a far less "hooked up" feeling both in terms of traction for launch, as well holding speed/traction in turns.
Would really like that "hooked up" feel all the time. Any thoughts?
As far as bleeding speed in turns, I would try Cobra fins, the new variety (super ultimate something) plus the new Fangs (mega?) will make your boat feel like it is on rails. Easy to return, too. I think I would go with ultimates, probably not Vipers(?) in your case if you want to surf? But I'm not sure. .....
That's a nice forum discount!I spoke to Jerry at Green Hulk about getting a volume discount for the Lucky 13 Cone (L13). Green Hulk has offered to give a discount for JB.net to anyone that wants to buy them. It is essentially a volume discount that you can buy individually as he feels he will get enough takers.
Here is how it works. Buy it on his site for full price and write in the comments box “$40 discount per Jerry” and he will refund the $40 immediately after the sale goes through. I just bought mine.
If you have a two engine it’s $40 off each.
Lucky 13 Adjustable Pump Cone for Yamaha SHO/HO Skis & Riva Race Pump [L13 YAM] : PWC Performance Parts
Hey @swatski I've been experiencing a ton of cavitation this year and my top speed is down about 5 or 6 mph. WOT RPM's are approaching 8k on both engines when they used to top out at around 7,200. I've looked under the boat at the intake grates for derby or obstructions several times and not seen anything nor a single nick on any of the leading edges of the blades.That's a nice forum discount!
The L13 is a must-do mod, IMO, especially in single engine Yammies.
Twins can do without unless one is pushing it, ballasting for wake surfing etc, then it is great help.
The pumps are more efficient saving fuel, but I also see it as a safety feature in twins - I can run on plane one single engine with ease, if it ever came to it.
Sounds like the impellers are slipping! Pushing 8k RPM you are hitting the electronic rev limiters that sequentially cut off the sparks starting at 7,900 or so, so I think you may have a lot to gain from sealing the intake tunnels and/or replacing the impellers. Any gap larger than 0.03” between the blades and the wear ring is bad, if it looks like you can easily slide a credit card in it's likely out of wack.Hey @swatski I've been experiencing a ton of cavitation this year and my top speed is down about 5 or 6 mph. WOT RPM's are approaching 8k on both engines when they used to top out at around 7,200. I've looked under the boat at the intake grates for derby or obstructions several times and not seen anything nor a single nick on any of the leading edges of the blades.
So, while I'm installing these L13's, aside from looking for obvious dings in the impellers or pitting on the back side of the blades which validates the existence of cavitation, what else can or should I inspect?
Note these L13's are arriving today just two days before we head down to the Beach so I'm planning on installing them and inspecting things while down there but I won't have the whole garage with me...
Another note: the boat has almost 300 hours so what do I look for for obvious ware ring issues or tolerances?
Thanks man!
