Magma Grill Mounts
JTrottaNY
Looking to buy a Magma Cabo grill. Does anyone know if either of the @JetBoatPilot grill mounts will work with this? JBP lists mounts for the "Newport" and "Trailmate" but the Magma website appears to be more universal fitment of their accessory mounts.
Following. Also looking at the West Marine sale.
I ordered up a grill from West marine while they where one sale, it should be here next week. I also got one of their mounts. Not sure if I am going to buy a 2nd table leg or use my original table leg.
I also got the Cabo grill and have been trying to figure out the same thing!
Just going to use my original leg
Did you get the mount from west marine or from JBP?
Keep your eye open here and on FB. I bought a second leg and tabletop from a guy that was selling his boat, I guess. Much cheaper than retail, and fits perfect.
I wonder where boats go to die? Like a U Pik a Part junkyard for cars... is there a place like that for boats where random parts could be retrieved?
Just closing out my original question for any one interested. I got the Cabo grill and the Newport grill mount from JBP- in hind sight I probably should have tried the Trailmate mount.
The newport mount comes with several sets of holes pre-drilled, none of which match up to the existing holes in the bottom of the magma grill. Fortunately there was plenty of material for me to space out 2.75" holes to match the four largest/widest holes in the grill. If you center the mounting holes over the center of the mounting ring, which makes it the most stable, the nuts that will eventually hide underneath the ring are also spaced out so that they do not interfere with the support bracing molded onto the back side of the mounting ring.
With about 15min of measuring and drilling its mounted and looks like it will work great. The only downside I found with the combo is the mount sits lower than the legs so you would need some type of blocks under the legs to use it on a table.
Again someone could try the Trailmate mount- maybe it comes with the correct holes predrilled but this combo can be easily adapted in just a few minutes. If I ever get to see a Trailmate grill in person I'll be sure to see if the mounting is the same as my Cabo! By then maybe Yamaha will add this spacing to the pre-drilled holes...
