Metal shavings coming out of rear drain plug.
Gym
Falmouth, MA (Cape Cod)
Oh wow mahalo(thank u) Gym, those look solid. I see what u mean as far as adjustability. I probably would have to order those online, don’t think the local stores or shops would have them. Great idea🤙🏽
Yes @rkim808 I ordered these on Ebay.
Gym
Yeah sorry I don't know of anyway to seal those up better. Maybe some one else will weigh in on that.
None of mine had hoses so I sealed mine with silicone.
rkim808
Kauai, Hawaii
Oh wow none of urs had hoses connected? It’s weird because the ones I figure would need drain hoses don’t have them. And I needed to silicon around the cup holders cause when I wash the boat like I said they leak. As for the broken/cut pieces of clamp, I gotta check all the clamp in the engine box. I noticed when looking to the far back of it, there’s a a half moon like large drain hole behind the bilge. It might of slid into the transom/exhaust area.🤔
Gump1976
Jersey shore
242 Limited E-Series
So I had been finding spiral metal shavings poking out from my drain plug almost every time I used my boat. I finally lifted the small door between the clean outs and shined a flashlight down to where the drain sits. Found a ton of junk that I was able to reach down and get, some of which looks like what others had mentioned. Small plastic bag, screws, clamp pieces, etc. Guess it’s not anything important, I hope!
mkbcaptain
East NC, Surf City.
My boat has that too. From the manufacturing process. Lazy
tdonoughue
The Woodlands, TX 77381
It is the Yamaha spare part program... Those are your spare parts. I hope you didn't throw them away...
212s
1000 Islands
Found one loose screw but no missing screws - probably just dropped during assembly. Lots of shavings of metal, plastic, and fiberglass, dust, etc. I put a hose in the forward section and let it run toward the stern with the drain plug out and the jack cranked fully up. After about 3 "rinses" I think I have everything out now.
Top Bottom
