yamahaar230honewb
- Annapolis, MD
Guys,
Yesterday a friend and I completely rebuilt our 2006 AR230 Boat Trailer. The brakes were completely gone and one was even missing. Just about everything was rusted so I wanted to make sure it was all good before we really got use out of it.
I logged on here multiple times to see what other people were doing to update theirs so I figured I'd give you guys some info back.
We replaced the actuator, brakes and lines completely. We bought those parts from TrailerPartsDepot.
Part number 80326 - 60.22 - Brake line Kit
Part number 34033 - 284.63 - UFP Disk Brake Kit 10"
Part number 47723 - 161.07 - UFP A-75 Inner Slide
All of those parts worked great. The brakes connect right to the axle, no extra plate needed and the hub kits fit perfect. The brake line it was great as well. Like most people, the only thing we changed was the bleed line screw to the top of each disk. The inner slide was a equal replacement and it was easy to bleed the brakes etc.
Then for the trailer we replaced the springs, shackles, bolts, pretty much all suspension. We ordered the parts from etrailer.com.
Part Number AP233 - 87.96 - Leaf Springs
Part Number - SP-051275 - 26.50 - Full rebuild kit for bolts, shackles etc.
We bought the Ubolts locally, 5" (4.5's do not fit FYI)
We also bought two new hubs locally and put those on. The exiting ones were so rusted the lug bolts were breaking off when we were taking the wheels off.
The process likely took about 6.5 hours. Not including dropping the boat in the water and leaving it during the rebuild. Most everything was rusted so we used a cut off tool from Harbor Freight on a lot of the bolts and all of the ubolts. Overall the kit that we purchased was perfect and fit the trailer like a glove.
The first two pictures are the old suspension itself. The next two are the finished product.
I didn't take any pictures of the actuator, but there isn't much to see there.
