2kwik4u
- Buffalo, NY
My experience is that keeping the poles in stretches the cover too much. After a few trips with the poles in, you could see a definite "pocket" forming on the cover where the bow pole was. The rear pole wasn't doing much damage or stretching, but I didn't like how the base of the pole was resting against the front edge of the engine hatch.@2kwik4u - I’m trying to understand the benefit of not using the poles. Also, does the strap that runs down the length of the boat go above or below your windshield?
So I took the poles AND straps out and tried it that way. It works just fine this way, and eliminates the stretching "pocket" over the front pole. I ran this way for a few trips.
Then I towed in the rain. When I got home there was a GIANT puddle in the bow, and it had saturated the cover and was starting to drip through to the carpet below. Not a huge ordeal, we were home and I put it in the garage to dry with the cover off. A few more trips through rain, and I decided to try just the straps without the poles.
With straps and without poles "feels" like the best bet for me. The straps prevent excessive stretching in the bow area, and help the cover to rebound to it's natural shape when you come down from highway speeds. I've also noticed that water doesn't pool as badly in the bow when towing in the rain with the straps in place.
So now, my process is to put the straps on, leave the poles off, then put the cover over and tighten everything as snug as possible. Pool noddle over the windshield in the center, and straps always over the windshield (and noddle). I'm not sure there is a right answer here, but this is what I found works best for me.
