I know the Richter scale is like that, that is one magnitude of difference is something like ten times the difference but I thought db was was measured / read on a one to one basis.
Anyway, here are my (max) readings:
No material:
79 db at idle, 81 db at no wake mode 3, 90 db at 6k rpm (cruise), 98 db at wot.
New material at the stock locations and seal around the engine hatch:
N/a at idle, 85 db at no wake mode 3, 98 db at 6k rpm, 100 db at wot.
Installation complete including fuel tank hatch:
76 db at idle, 84 db at no wake mode 3, 95 db at 6k rpm, 98 at wot.
For comparison on the trailer (out of the water)
Engines off (just surrounding noise): 63 db
No material at idle 84 db
Installation complete 84 db.
If I was going just by the readings I'd say I was better off with no material at all. I will not put any weight on my opinion since I may just be in a fools paradise trying to justify the time and expense but my crew had no idea what the readings were they (and I) can tell that there is a huge difference in the sound and the volume we need to speak at now that the material is installed. Again, I'm open to taking new or additional readings in a different way or with a different application if anyone is willing to do the same on their 240 series boat for baseline comparison purposes.
Here are some pics of what I see on my db application.
