Hoyt
- Suffolk, VA
- Limited S
So the audio equipment has been ordered and the plan is about 95% set. The boat will have the following:
(1) Wet sounds SD6 amp
(2) Wet sounds SD2 amps
(4) Wet sounds REV 10's
(8) Wet sounds Revo 6 coaxials
(2) Wet sounds Revo 10 subs
I plan to remove all 6 of the OEM Wet sounds 6.5" speakers. They are their "Recon" series and although I'm sure they are decent, I don't think they'll have the power handling capability for the SD6 amp so switching them out for the Revo series as well as adding a pair mid cabin. The OEM subwoofer is a Revo series, so I'll keep that and add another one most likely on the starboard side somewhat in the same location as the factory one on the port. They will be run off of the first SD2 amp. I am a little concerned with not having enough bass this time around, but I did keep my XXXV2 from the last boat just in case ?. Tower will have 4 REV 10's with swivel clamps running off of the other SD2 like the last boat. I'll be running 3 batteries (one start and two house) on a two bank charger. This set up worked well for me before so I'll stick with it.
The garage is already stacking up. All my power wire is in, RCA's are in, New Fusion plug for the stern head unit, and a big sheet of King Starboard.
Yaaaaaaasssssssss
