- Corinth, TX (DFW)
It's not making a vacuum, I pulled the mounting boot and rolled the oring around underneath it and reapplied the boot along with a small smear of grease to help get a good seal on the pump. Almost seems like the piston inside the pump is loose although you can hear air pushing through when you pump it??
Anyone have experience with one not working correctly?
