- Royal, AR
- SX
I added a second battery last year. My primary reasoning was to provide additional power for the refrigerator which is a 1 amp hour 24/7 load. I used DieHard Platinum Group 31 AGM batteries which have worked very well so far. Both batteries are connected to a battery disconnect switch where I can choose which battery is powering the boat or use both batteries at the same time. The factory engine cables are connected directly to the battery disconnect switch. The house load is connected through a low voltage disconnect (LVD) preventing the house load from running the batteries so low that they would be damaged or could not start the engines. Both batteries are charged via an on board charger when shore power is available.
I considered using a typical starter and house battery setup. With two batteries of equal size the capacity of the starter battery would be wasted. If I wanted to have a true starter battery it would be a small one. Our engines are small and a jet ski sized battery or small motorcycle battery would be sufficient to start them. I decided that I wanted to make both batteries available to the house loads.
When I started using this setup I would turn one battery on at a time leaving the other as a backup. I did not want to risk needing a jump if both batteries ran down. Now that I have become comfortable that the low voltage disconnect will prevent battery discharge and with the electrical load of my boat I leave both batteries on.
One interesting discovery is that that key switches are powered through the house load wiring. So you must have power to the house circuit to start the boat.
The low voltage disconnect has an override switch that reconnects the house loads when pressed. The override switch needs to be connected to a power source that is not switched by the LVD.
Using this setup I am able to run the refrigerator for approximately 100 hours before the LVD disconnects the house load which is very convenient for multiple day outings. At that point the batteries are at a 50% charge leaving plenty to start the engines. Using a traditional setup would halve that run time. This would also benefit members who want to power a large stereo setup.
