Going to revive a somewhat old thread here.
Wife has OK'd another upgrade of the stereo system this year. It will be a mild upgrade with (4) new speakers, (1) amp, and (1) 10in sub. Currently only have the factory stock head unit, Wetsounds Stealth 10 Ultra soundbar, and the rest of the factory loads.
With the new stereo I would like to upgrade the power reserves on the boat, but want to keep it as SIMPLE as possible. We currently run a single smaller battery and have never had any issues. I'm considering moving to two slightly larger batteries, and wiring them such that they are in parallel. The thought is that I don't care which battery I pull from at any given time, I just want a larger pool of energy to start with. I already have a single battery on/off switch, and this serves us well to keep stray loads down. We will be carrying a Li-Po jump pack with us, and on a single engine, reserve power is not really an issue.
The goal would be to get a good solid 8hrs of stereo run time at moderate volume levels, be able to restart and get the boat back on a trailer. Only a few times a year will the boat be left in the water overnight, and in those instances I can run an extension cord to the dock to recharge if needed. When at home the boat stays plugged in to a battery tender type device to keep the batteries topped off.
SO......my questions
@Bruce Can it be as simple as purchasing and mounting another battery next to my exisiting battery and connecting the posts togethor (in parallel)? That would be an ideal "simple upgrade" for me. How do I check that my tender is acceptable for the larger capacity? My thought is it will simply take longer to top off than before because the pool is larger. Correct?
@swatski You mentioned upgrading some time back in this thread (it's like 3yrs ago now). What did you end up doing? You have a pretty good read on getting the most value for your mods. I'm curious if you ever put the LVD in place.
Thanks to all!
