Navigation lights. LED?
Foobar
Charleston, SC
Anyone know if the navigation and anchor lights on the 210 FSH are LED? I haven't really taken the time to seriously check, but the anchor light looked like a standard bulb when I had it on the other night. The navigation lights looked LED as they were damn bright.
My sales guy said all of the lights were LED, but this is the same guy that didn't even tell me there was a YES warranty available.
I know on my 16 ar240 that the nav light bulb was a standard festoon bulb which i switched with a led bulb from Drled
My anchor light is stock led
Don’t know if this helps but my 2017 212 LTDS is all led
Thanks. I will probably pull them apart to double check.
I was told the same, that it was led
I just looked in the service manual and there was no mention of light bulbs at all. It has how to test the switches for it, but does not mention the bulbs at all.
No idea on your boat. I switched to all LED last year, everything, including the instrument panel lights. The toughest part was the festoon bulb in the nav light. Went through three brands before I found one that worked properly because even though they were marketed as "Navigation" lights, they made the green look blue. Finally I got one from West Marine but although sold as a 31 mm it was actually 33 mm. There isn't enough clearance on my boat for the cover to fit so I had to use a drill and modify the baseplate to fit the longer bulb. All good now!
