Cambo
- Long Island
- 242X E-Series
A rubber cork is stuffed in mine the water pours through the cracks as fast as that drain could let water out . The multiple through hull fittings have silicone that had a lot of non adhering spots I have peeled the loose junk re siliconed. Every hose clamp took a few turns without putting to much stress. Screws and self stick neoprene was added to both parts of the hatch . Under regular conditions I probably had a gallon or two while surfing the bilge pump runs 2 or 3 times while out . Next I'm looking into something for the cleat maybe some rubber hose wrapped on the on the shafts. If I was in fresh water I wouldn't care I don't like all the salt water sloshing around down in the hull .
