Daren and Heather
- Prior Lake, MN
Hi, so I have a 2020 AR210, first boat ever... Taken it out 6 times, never noticed issues with lots of water from the drain plug. For the first time over the 4th of July I left it sitting docked in the water for 3 days (battery off while docked) and over those 3 days we ran it pretty hard and did lots of tubing, driving WOT, making really hard turns to create wake and do jumps with the towable, etc. No rainfall during the 3 days. On the final day, when clearing out the wet storage compartment, I noticed water pooling at the bottom of the drain of the wet storage compartment. There was nothing blocking the drain, it was just like the bilge was completely full to the point the water was coming up the drain. I turned the bilge pump on and I heard it run. I turned the switch off, and the bulge pump turned off. Later that day, when I pulled the drain plug it gushed out water for maybe 3 minutes! And there were maybe 2 inches of water above the cleanout plugs.
1. Shouldnt I be worried that it appears the bilge pump wasn't already running automatically?
2. If I saw water slightly coming up above the wet storage compartment drain plug, does that mean the bilge is completely full?
3. Should I take to my dealer whole under warranty, or is this normal when you drive it hard like I did and leave it docked for 3 days?
