14SX190
- South Florida
- SX
It looks like my used boat is starting to show its true colors.
I went in with idea to check everything at the water test from day one weeks ago. It performed like expected and had compression, I was happy. Never checked the oil! BIG MISTAKE
Flushed it when I got home and it sat until I went out for the first time a few days later.. Came home flushed it and away it went in garage.
No alarms went off of lack of power during both outings
I am aware of starting boat first then water. Water off then engine off. I don't know history from previous owner
It had the marbles sound in the pump at water test and didn't sound better when I took boat out first time.
I watched videos and sure enough 6 bolts and the whole assembly came out. Followed other JB's post on using car tire to wedge ratchet on one end and breaker bar on other end prop came off like butter. Had to get drive shaft rethread as head got mushroomed trying to remove shaft from pump.
All the parts ordered from Partpak and waiting for delivery
In the meantime, I went to do ribbon delete. I hope I got the right PN#MWV-RIMUK-FZ-11. Otherwise it will be for sale.
Anyone can confirm. There are two sizes or change from model to model? And there I saw the milky oil.
Took oil cap off and it was like butter. My little harbor freight pump could not draw any oil from dipstick.
I read poring ATF down crank case would help and with my buddies west marine oil pump worked much better.
It has been 5 gallons later and still looks dark shade of brown. Is there something the dealer does under vacuum that will recirculate oil until new oil is pumped through? Its getting expensive.
[HASH=3752]#swatski[/HASH] has thread if you remove some bolts on the front of the motor you can get suction tube lower into oil pan VS dipstick. Anyone else try it that way. To get to one in back of engine you need to be contortionist
2014 Yamaha SX190 (RX1800DN) Crankcase | Babbitts Yamaha Partshouse pn#27. Leaves a space to get into oil pan. May have to try that trick
So I keep reading and found a couple threads about the exhaust manifold having casting problems. So off it comes. I have attached picture for reference and of the gaskets? Do those gaskets look OEM? Some of the black paint was stuck to water jacket port(in picture) on top of all that scale. Is there a way to clean that with removing head? The exhaust manifold looks intact. Opinions? Is there a service manual link I can reference torque numbers for reassembly?
Also, there is a blue wire near the tip of exhaust to a fitting right before rubber coupler to water box. Is it electrical?
Could it be oil cooler? Need to start reading up on testing procedure.
Any other possible explanations as to water in the oil? Anyone local to me willing to give me a hand
I appreciate everyones time in reading thread and help in solving milky oil mystery so I can start using Boat.
