mitchsee
- SX
Hi all,
I'm new to this forum and also brand new to the boating and jet boat life. I just bought a used 2017 Yamaha SX190 and had no issues taking it out Wednesday and Thursday. I pulled some tubes behind and hit a good cruising speed of around 30 mph with 7000pm. Yesterday, I was coming back in from an evening ride and got an error message saying Low Oil Press. So I checked the oil and filled it to about the midway line of the two holes in the dipstick.
That seemed to work for a bit. The alarm went away and was able to get back to the 7000 rpm and 30 mph speeds I was getting. However, after cruising for about 15 minutes, the rpms dropped to 6000 at full throttle and speed dropped down to around 12-15 mph.
I cleared the jet board of any obstacles and rechecked the oil to make sure it was still at a good level.
I've also noticed that my rpms will drop down below 5000 rpm when making a sharp turn and speed will go down to around 10mph.
I opened the engine compartment and see a bunch of water spraying. I uploaded a video to imgur here: https:// imgur.com/a/yamaha-XIFNdUX
Any advice or feedback is certainly welcomed! Or, if you have a mechanic in central florida that you'd recommend, let me know!
