Need some help: Another Reverse Gate question
dscable
Crawfordsville, IN
OK guys. I had to replace the reverse gate cable about a month ago. Boat is running fine, but feel like I lost a little bit of speed and "hole shot" power ever since. Took some time to look at the reverse gate again today, and notice that at WOT it doesn't appear to clear the whole nozzle (see pics). That doesn't seem right to me, shouldn't the gate be completely up? If so, I have maxed out the adjustment, and the lock nut is all the way up the threads so no more adjustment space.
Now - I noticed on the parts diag (see pic) that part 42, called a collar, is missing on my setup. I assume that those collars allow that bracket to "swing" in it's connection points. Could this be my problem? Mine is tightened down tight and doesn't spin at all. To test, I loosened the bolts a bit to allow for the freedom of movement, but it didn't APPEAR to make that much of a difference.
Any ideas??
GTBRMC
Waukesha, WI
I believe @Cobra Jet Steering LLC has vast knowledge on this adjustment - fairly sure he has answered this kind of question before (going from memory, so not 100% certain).
Bogus
Any ideas??
I have changed the cable on port engine today because of electro corrosion. I can definatly say that you need to make the gate open fully at forward. So you need to fix it.
dscable
Crawfordsville, IN
Thanks for the reply.
Was hoping based on the pictures someone might be able to tell me if the position is way off compared to theirs or others.
tdonoughue
The Woodlands, TX 77381
The adjustment is to screw part 37 up closer on the new cable. Use care or you will snap your new cable tightening the bolts (ask me how I know).
If your 42 collar is really missing, that will cause extra play in the gate (you will be able to lift it up and down and see it flopping about until it contacts the cable end). However, if I recall correctly from replacing mine the collars usually stick inside the gate. So it may be there and just never have come out for you to notice it...
Vendor
Florida
You must adjust the cable to get the entire reverse gate clear of the water exiting the nozzle I am surprised you don't feel some serious vibration in the controls when you are on plane, also you must have the collars in the reverse gates so the bolts can be tightened properly without binding up the reverse.
dscable
Crawfordsville, IN
Thanks guys. The problem is there is no adjustment left in the cable. I am at the top of the threads on the treaded rod from the cable if that makes sense. I do have play in the gate, and do not have any vibration while I'm on plane, so maybe the force of the nozzle is enough to push the gate up clear even though it doesn't appear to go up all the way when on dry land (makes sense in my head anyway lol) I ordered the collars from partzilla, ill see if that makes any difference. Otherwise, I'm not sure how to adjust the bucket any higher.
Vendor
Florida
That is common you should have more threads left to use but the cable has bottomed out in the cable connector so if you have a 1/4 inch of cable threads left just shorten the threaded end of the cable that much and it will allow you to move the end forward a bit more and get the bucket out of the way the jet thrust will not move the gate out of the way it will just interfere with it. The small standoffs may get the bucket further up so do that first .
dscable
Crawfordsville, IN
Thanks! I had thought about cutting the threads down in case I was bottoming out, but was trying to check all of my other options first 😅 I'll wait for the parts, and if those don't help, I'll pull out the cut-off wheel. Thanks as always guys.
