Need to know how to replace drive carbon seal - 2014 Scarab 215HO
John P Jones
Scarab
HO Impulse
So, I did that thing that should never be done - I ran over a tow rope - sucked it in.
Yup - shut it off - opened the engine bay - and saw the water coming in.
We got the boat out of the water with the bilge pumping like mad. Seemed like the bilge did its job.
When I took the jet pump off, I was able to get the rope out - and found the plastic seal end of the carbon seal chewed up.
I'm assuming the carbon seal is shot as well.
Do I need to remove the shaft to replace that seal?
Do I need to remove that outer sheath in order to remove the shaft?
Any links to videos and such?
I have the information you're looking for. PM me for details.
Send me this info…I have the same question. Thanks!
I was away for a few days. Check your PMs
I also have a leaking seal. Would you please send me the info to do myself. Thanks!
