haknslash
- Lake Martin, AL
- Moomba
- Other
Ok after going out in the pouring rain I was determined to see if it is indeed possible transform my tow package F150 bumper to a non-tow package F150 bumper so that I could buy and use a Curt Class IV hitch. And the answer is yessir!!!
Check it out. After looking at the Curt Class IV hitch for an F150 without factory tow package I watched their video and noticed the differences between their bumper and the one that comes on a factory tow package F150. My truck use the lower 3rd bolt where as a non-tow package bumper just uses the middle and upper bolts. This means their bracket is a little shorter than mine which leaves the slot in the frame exposed to mount an aftermarket hitch. The other mounting location they use is up by the top of the spare tire which is fine on either truck package. It's the factory tow hitch and extra bracket material that needs to go...and it's certainly possible. Below I've marked up some screenshots from videos and pics of my truck to explain how I'm going to do this in case anyone else wants or has to do this.
F150 without tow package. He is showing in the etrailer video where you will insert their supplier fasteners once you have the hitch in place.....
Once you remove the rear bumper you will need to remove the metal bumper caps on each side. This will give you good access to the hitch and brackets where I will cut....
Below are pics of my truck and factory tow package bumper. I've marked where I will continue cutting the bumper bracket so that is is shaped like a non-factory tow package F150's bumper bracket. Remove bumper like above and cut along this line on both driver and passenger side brackets. After that I should be able to install the Curt hitch. Then I will reverse the steps of dissembling the bumper caps to the bumper and then mount the newly modified bumper bracket assembly to the frame of the truck....
This can be such a confusing topic. Here is a reasonably informative (and short) recent discussion of P- vs LT-metric tire pressures, from my other favorite site (feel like a cheater here, lol).I know the many things make a difference once talking about getting super accurate with pressure for load. I don't know what the best answer is for all the different combos beyond more pressure for more load up to the tire sidewall rating. I run 35psi for daily 40psi for long tows in my current setup. Plan on the same with these new ones unless someone tells me differently for soft compound V rated light truck 305/45 R22 tires. I may have to do some googling on my specific tires now that you have mentioned it and I am curious.
Looks to me like your receiver isn't the issue. Is is rated for 11000 lbs with a weight distribution hitch. Weight distribution hitches mount to the same draw bar as the ball. so the receiver is more then capable of 6000 lbs. That is fords rating for the truck not the receiver. They believe for it to handle properly towing more then 6000 lbs it needs a weight distribution hitch.
The thing is I’ve never seen anyone at the lake using a WD hitch. Ever. It’s more expensive and more of a hassle than just upgrading the hitch to Class IV and be done with it. No having to unhook the bars to maneuver or back up down the ramp. No popping in tight radius. I asked my dealer if he has ever had afnyone use a WD hitch for pulling a boat and he said no. Not saying people don’t do it but you see them mainly used for travel trailers. When I was a kid we had them on our travel trailers and I remember getting out every time to unhook the sway bars when we would have to backup into our spot. Just don’t care for all that. I’m going to try and get by the dealer on Saturday to hook a big boat to it and see how the sag is. Dealer said my truck will be fine and that many people use 1/2 tons without issue. Once I hook a boat to it I’ll see how it looks and go from there if it looks or feels unsafe. I think it will be fine though.
(can skip to reading just the two or three "gaijin's" posts, without missing much)
Do I really need an LT rated tire?
Personally, I have never had a car or truck where the OEM tires would NOT already exceed maximum capacities of the vehicle, but I also find disadvantages of all larger/heavier tires generally unattractive (to me).
In the last 10-15 years wd/sway bar hitches haven’t gotten considerably better. At least the higher end models. Hills and tight turns/backing up can all be done without unhooking anything.The thing is I’ve never seen anyone at the lake using a WD hitch. Ever. It’s more expensive and more of a hassle than just upgrading the hitch to Class IV and be done with it. No having to unhook the bars to maneuver or back up down the ramp. No popping in tight radius. I asked my dealer if he has ever had afnyone use a WD hitch for pulling a boat and he said no. Not saying people don’t do it but you see them mainly used for travel trailers. When I was a kid we had them on our travel trailers and I remember getting out every time to unhook the sway bars when we would have to backup into our spot. Just don’t care for all that. I’m going to try and get by the dealer on Saturday to hook a big boat to it and see how the sag is. Dealer said my truck will be fine and that many people use 1/2 tons without issue. Once I hook a boat to it I’ll see how it looks and go from there if it looks or feels unsafe. I think it will be fine though.
That gaijin guy gives some good advice.
I had P's on my Yukon and it rode WAY too soft. Moved to LT's and was much better. This Sierra came with LT's and I'm considering a drop back down to P's as it rides far stiffer than I like.
Keep in mind "P" tires are supposed to be derated by 10% (I need to verify that number) when being spec'd for "heavy duty use" on fullsize pickups. There are plenty out there that will still exceed your axle rating though, even at the 10% derate.
And they haven’t gotten easier to hook up.
I was under the impression that the WD hitch is needed on smaller trucks to avoid overloading the rear axle weight rating.It just occurred to me, what you are really trying to control is tongue weight. In a travel trailer, there is little you can do to adjust that short from moving one or two things around in the coach. On a boat trailer, move the boat back until you hit your ideal tongue weight or about 10% of the load. Adjust the bow stop to that point. Do we know what the tongue weight is supposed to be?
Can’t say I’ve put a lot of thought into it. But i can’t see that happening... Especially with the Anderson that uses chains.You would probably want to to unhook your bars before unloading the boat from the trailer. All of that lever weight has to go somewhere and it would either bend something in the tongue or assembly on the trailer or lift your rear end way up, which would probably be unwanted on that ramp!
You are distributing the weight across the entire truck and trailer and not just on the bumper area.I was under the impression that the WD hitch is needed on smaller trucks to avoid overloading the rear axle weight rating.
