- Rosebud, Mo
- 242X E-Series
I bet there is still something in the idle circuit. It revs too good after idle for there not to be.
Have you tried spraying fuel or starter fluid while trying to idle? watching it idle with the spray would give you the confidence that the issue is fuel starvation. The bad is that starting fluid is very dry, and this being a 2 cycle there is always the risk of running too lean. Maybe a spray with a bit of fuel premixed with 2cycle oil can assist, instead of starting fluid.
Bottom line, it looks like the idle fuel is not being provided.
