@BigPapiBT Congrats on the new boat!
Your list has mostly good stuff but I wouldn't use that hull cleaner "Lysol toilet bowl cleaner" - it'll probably strip the wax off. Better to use a matching spray detailer to buff up the hull. You could use the cleaner end of season to clean off some build up perhaps. Same for the erasers.
Also I don't like hull hugger fenders, prefer the traditional round, long fenders - they work well.
Your battery tender - make sure it's ignition protected if you put it under the seat so it doesn't ignite flammable fumes from the battery or fuel tank. There are marine specific models that are waterproof and won't ignite a flame, and some models can be mounted in the boat so you just need to plug it in. Many use a Noco or Promariner to keep batteries topped up and during winter storage.
You will need a few 15-20ft dock lines to tie off. The bungee ones are good once you tie off to hold, but you need proper 3/8 or 1/2 inch lines for secure tie off and in case you're at a dock where the cleats are more than 4ft away.
The 50ft tow rope for the tube might be too short. If you're pulling directly behind you while on plane, the spray from the jetpump will probably be a nuisance to the riders. If you're good at it and can keep them riding outside the jetwash, then 50ft is fine. If they just want to tow behind, then you'll probably want a 10-20ft extension to get past the spray range.
You may not need thrust vectors from JBP - the boat comes with an Articulating Keel or rudder that greatly enhances steering. Older models needed aftermarket steering accessories but newer do not. I thought I would need to buy a set when I bought my new Yamaha but after getting the boat in the water, I found it handles almost the same as the old I/O prop we had. Some may want to add it anyways, but you may not need it - personal choice of course.
Check your safety kit to make sure you have everything needed for Coast Guard approval, it varies a bit depending on length:
Discover amazing destinations and plan your dream vacation today
www.boatsafe.com
And if you don't have navigational experience, I highly recommend a boating safety course to help with navigating the waters safely, proper operating procedures, aids to nav (buoys and colours), etc. Winter is the best time to do the course while waiting to go boating.
