kaczman
- Limited
Hi all,
Just picked up a beautiful 2011 Yamaha 242 Limited. Just a few quick questions:
Anything I should lookout for? Engines fire right up, hull and seats are in good condition. We just winterized it (changed oil, winterized the motors, pulled cushions to be reupholstered)
No fins on the end of the jet drives. Any suggestions?
Obviously being a Limited and not an "S" there is no wakeboard tower. Any suggestions on adding maybe a used one from an "S" or aftermarket replacements?
Im going to replace the speaker system. I keep reading the tweeters are mounted on the tower - I assume if you don't have an "S" there are no tweeters on this setup?
I pulled the oddly sized aquatic AV AQ-SPK7.5W speakers. It looks like the mounting cutout is the same for a 6.5" speaker to replace it with. I also read the that rear speakers are bridged together, so I'm assuming ill have to run new wiring form the old head unit to each speaker? Or just the speakers in the rear deck and swim platform?
Obviously in 2011 the only color available for a 242 limited was Yacht Blue. Anyone know where to get some touch up paint for the damaged areas?
The boat will be used for pleasure mainly on lake erie. Any suggestions and upgrades any members would like to share for a more enjoyable experience? I have to figure out a portapotty for the head area too.
		 What happened to the 230?  Problems that caused you to dump it so soon?  Mine is a 2016 242, so not sure I can give you any info since they have changed alot.
