VitaminSea
- Central FL
- 252SD
we had an uneven load but had more weight on the port side so that wasn't it. wind was a factor but had different headings all day and always was always pulling to port side to some extent.
ah, gotcha. As you check the alignment, also check the buckets in Neutral, Forward and Reverse. If the gaps are uneven that could account for the pull. Good luck.
