MGoMike
- Michigan
- X
I picked up my new 2019 212x earlier in April and have been making some mods while waiting for the weather to warm up here in Michigan. Today, I was planning to install boat buckles and ran into two issues that I wanted to get the forum's wisdom on:
1. We got the deluxe premium mooring cover when we purchased the boat. It had rained a bit overnight. When I took the cover off today, I found that it was damp inside the boat. Is that normal? The carpeting in the front under seat storage spots were pretty damp.
2. When I went to install the boat buckles, I discovered that the Shoreland'r trailer transom tie-down tabs were both bent backwards at different angles. The tab next to the license plate is bent at a relatively shallow angle, but the tab on the other side is bent enough that it isn't possible to install the boat buckles. This wasn't something I thought to check when taking delivery of the boat. I can't imagine anything that we could have done in trailering the boat to our storage spot that would have bent those tabs. I'm planning to contact my dealer, but before I did I wanted to check to see if this is an issue that others have had and any ideas on a potential resolution. Seems like simply bending the tabs back would significantly weaken the metal. I attached a couple pictures though it's kinda hard to see the angles in the photos.
Thanks for the help on this.
