ralphsmithiii
- Tampa, FL
Pulled the trigger on my first round of upgrading the stereo on my 15 AR240. I went with what I believe is a pretty popular/proven setup, all provided by Odin@Earmark.
To start, I'm upgrading the factory speakers to MX650's in Sport Gray/Titanium then adding another pair in the cockpit area. I'm also adding (1) JL M10IB5SGTB, running all new speaker wire and powering all of it with a JL M800/8 amplifier. That should give me a pretty decent start to enjoying the stereo on the boat while cruising. I may either add a set of towers or rear deck speakers for when we hang out behind the boat at the sand bars.
With that, I've seen several pictures where people have mounted the JL IB sub by cutting a hole in the starboard side storage compartment. So far I'm planning on going that route, adding the sub with enough space to possibly add a second down the line. I'd add an additional amp as well, etc..etc..
Here's an idea of what I'm looking to accomplish for reference (starting with 1 IB sub for now):
However, I've recently seen a few posts where people have mounted them on the port side storage compartment area. I think you could possible squeeze two there or maybe go 1 port 1 starboard.
What I'm wanting to know is there any real advantage on mounting to either location? My initial thought was shorter wire runs on the starboard side but the rear of the sub would take up some space in that storage compartment. Mounting it on the port side would mean longer wire runs but have to run new wires anyhow and the sub sticking out into the battery compartment wouldn't be any lose of real space.
Anything else I'm missing in regards to mounting the sub or is it 6 in 1 half a dozen?
