- Naples Florida
- SX
That spin out seems crazy! Are you sure that your steering and shift cables -are both good?
I know nothing about the Tangos, but just wanted to welcome you aboard jetboaters.netHi Jeff & Deric, this is Kurt, I'm the guy Jeff talked to that lives in Cockeysville MD. I was telling Jeff that I thought your boat was the one I saw on Craigslist last year when I started looking for a Tango. I figured there weren't too many 2008 yellow 4+2's sold on the eastern shore recently.
I bought a 2000 Tango 175 hp primarily for tubing and kneeboarding, and it works great for that, but is incredibly difficult to drive. The first time I had it out, I was driving straight in calm water and it did an unintentional spinout (360+) at 45 mph when I simply backed off the throttle. I understood that spins and slides were possible with the boat, I just thought they would need to be initiated deliberately! Since the 360 incident, I haven't taken it up over 30 mph. When searching for a reason for the handling problem, I found that the stock trim plate was bent and adjusted all the way out to push the nose down. I thought that might have contributed to the high speed spinout. I replaced the plate and readjusted it to a neutral position. I have found that this has not changed the handling problems at 0-30 mph, however, due to having shoulder surgery, I am unwilling to do a high speed test run until I am completely healed.
I have some questions about your experience with the boat before & after Cobra fins. Have you ever experienced the type of problem I had with the boat spinning out without trying?
The one concern about the Cobra fins is do they ever grab and cause problems in turns or slides? After reading your posts and speaking with Jeff I am going to install the Cobra Jet fins and I would like to have an idea of how they are going to perform.
Any information would be greatly appreciated!
Thanks,
Kurt
My Mirage 240 will also turn right with less effort but not near as bad as you seem to experience, I think it may be the nature of the beast.As to turning when decelerating something isn't right.I would look closely for excess play or something worn in the steering, mine has almost no slack when you try moving nozzle by hand.Hi all,
Thanks for all the responses and happy to have found this site, this seems like a great forum community!
This is my first jet boat, but i have 1200xl wave runner that have I towed kids around with for years. I never had a problem getting used to the steering or handling on the jet ski, but this thing seems like a totally different animal. Maybe i pulled off the throttle faster than I thought, but i definitely didn't yank it back.
The other thing that bothers me is that most of the time the boat tends to pull pretty hard to the left. The steering effort is easy if you want to turn left but is much harder when you turn to the right. Also, when running straight and , decelerating off of a plane, if you hold the wheel the boat turns on its own, if you reapply throttle (still holding the wheel) it straightens out ?? Is this a characteristic of a single engine jet boat, it seems like most small jet boats have twins and maybe its to overcome these issues ?
Hi Kurt I had the same problem. Once I put the fins on my boat it stopped. Cobra steer will make you feel like you're in a different boat. Welcome aboard!I know nothing about the Tangos, but just wanted to welcome you aboard jetboaters.net
Change pump lube,fog engine,and stabilize gas is the most I ever do been known to skip any and all steps and have never had any issues.Engine is self draining so no worries there though I do have heated storage.Just wondering what do you guys do as far as winterizing your boats.
@Kurt I have the same problem with my 1998 Tango Kurt. I have been told it may need steering cables, possibly caused by the cable sheath being too close to the exhaust and melting it. I will be looking closer tonight as I just got mine at the end of last summer and haven't had much seat time. But that easy one way and hard the other is a PITA ! And dangerous. I have to beleive something is wrong. No one could sell a boat that did this!! I have also experienced the sharp left when dropping the throttle. mine happened several times when the motor bogged out from electrical issues. Will be checkin the broken vane thing as well after reading this thread.Hi all,
