Krokoscarab
- Scarab
- 165 ID
Hi, My name is Dan and I am new to jetboats. I have just purchased Scarab HO 165 ID 2018 with 40 hours on the clock. I had it on the water about 10 times now. Never a problem, except last time I was out the boat would not start initially...three attempts and it went finally. Today, after about three weeks of sitting in the storage the boat would not start again...battery is full, gauges work, fuel pump is making noise, but no starter when you turn the key. I checked the fuses, connections etc. All seem fine. I put two cables to the starter contacts directly from a battery to test the starter... no sound or movement. Does it pretty much mean the starter died? I am also amazed to see the starter just hanging on the bottom of the motor, where the water always swooshing around... any pointers or anything else I should check before buying a new starter? The boat out of warranty, so I will be working on it myself more likely. Thank you for any info. Dan
