Hoosiercuts
- Plymouth IN
- SX
Run with the filters, then run without them. If there is mo difference don't bother changing them. If you do notice a difference in max RPM or max speed change them.
P.S. Do not overfill the oil. That's a very common mistake on MR-1 motors. If you suck out 2.5 quarts replace it with 2.5 quarts. You do not want to see anything above the L mark on the stick of a cold engine and preferably lower. Make sure your boat is sitting level or in the water when you check the oil levels.
I just bought the boat 4 days ago. When I pumped the oil out of the compartment it looks like a mocha color. Maybe mixed with water ?
