4x15mph
- Downingtown, PA
I added an amp last season (4 channel, 75x4) and upgraded the 4 OEM speakers to Polk 6.5 MM1 series. The sound is much better than the stock
I would like to keep going on this and think a subwoofer with separate amp might be the next step or would I get better sound by adding wake tower speakers? I am thinking the waketower speakers would focus on the rear sound versus all around in-cabin sound. I also think that I could use the crossover with the sub to fine tune what I have now....
1) What do you think and any good recommendations on a somewhat plug and play, sub and amp? Can I do this without adding a sub box or would that be a big compromise and defeat adding the sub?
2) Should I focus more on adding 2 more in-cabin speakers to take this from 4 speakers to 6? I am thinking I should do that regardless and I would probably run the 2 new speakers in parallel on 1 of the channels of my 4 channel. Suggestions on placement given I have the OEM AR210 setup (2 speakers in the bow, 2 in the cabin)
