No power and reverse module error
Liberty195
Scarab
195 Open ID
When we sea trialed my 17’ 195 open at first there was no power at the ignition. Turn key and nothing, as if the battery was dead. Tried brokers jump box and then mine, nothing. Goofed around with it for a bit, then turned on blower and it started. They told me that the blower needs to be on in order to start it (which is not true). Ran great at sea trial and then I ran it a few times in the driveway winterizing and what not, all good.
Fast forward 3 months to last week and again, turn the key and nothing from the engine and to add to it there was a reverse module error on the screen. Mechanic was already there as he came to inspect my supercharger. He chased through my ignition and nothing. He determined that the reverse error was likely due to no power to the engine. I then got on this site and saw that someone else had the reverse module error and ended up taking it to a dealer who replaced a relay and that solved it.
So my mechanic went to the relays. There are two 30a large black relays plugged in to the fuse box back by the battery switch. He did some meter testing back there, then swapped them, and viola, fired right up with no reverse error. He then replaced both relays as they are only around $20 each and all good now.
Wanted to post this experience.
Very common. I recommend you keep a spare relay or two in the boat like fuses. They can randomly fail of course, but many times it's a temporary short or something similar during battery terminal connections and such.
Keep in mind that reverse module error seems to be a default catch all error. Lol A lot of people have these with vary different root causes. But the relays are commonly associated and specifically with the engine not turning over.
Thanks for contributing to the forum knowledge base.
Thanks Luc! Agree will get a spare or two to have on hand. Thanks for the note on the reverse error kind of a catch all. Good to know.
Where can you get these relays?
Thank You. No one in our area seems to be able to work on scarab boats.
I hear ya. Same here. Sea-Doo dealers require a different BRP license to access the computers. And they don't want to buy it because there are so few of these boats here. It's nort worth it. Plus boats take more physical space than a PWC at the dealerships. So they're even less inclined. It's definitely frustrating unless you have an actual Scarab dealer in your area.
Prices are all over the place for these. Dealers charge a small fortune even though they are extremely cheap elsewhere. But yes, they are the correct ones. There are other brands too that work.
Awesome, thanks. Just to be safe, these relays fit other years of Scarab 195? Such as my 2014 for example?
All years. They are all the same. Also fits Sea-Doos PWC.
Perfect, thanks! Ordered 2 to have on hand, just in case.
And OP, thanks for the post with the fix! Much appreciated!
Good catch on the $20. $20 each was for the oem relays that my mechanic stocks. Actually I think they ended up $15 or $18 on my invoice. That’s what he used. I researched this site and found the link I sent you to the more affordable ones. Still GM oem, but not rotax. Glad you are all set!
