No Power
throttles in neutral? sounds more like a kill switch issue than a fuse issue to me. or possibly a battery switch issue.
I know the switch is no good there's power to it but not from it and it's free flowing continuity in off. Just not reaching back to the main, bypassed it and got power. Throttle is in neutral. Did take the tether off the kill and put it back on could be an issue. Won't know until I pull the panel off but it's definitely a consideration for the issue.
Found this thread regarding similar issue. Wonder if it is relays?
After finally getting around to going through every fuse (no bad fuses minus the bilge) I had continuity to the battery switch but not FROM the battery switch, upon tracing back all the wires to the switch and reorganizing and connecting them correctly (previous owner) and relabling the common, house, bilge, battery switch etc) and replacing the bilge fuse I still had continuity to the switch in the off position 4 way selector had 8 positions so something inside the switch was gummed and corroded couldn't even pull it apart. Decided to bypass the switch entirely to test and hooked everything into battery 1 and 2. Fired right up. New switch will be here today.
Excellent! Thank you for closing the loop! Let us know about the new switch install.
Assuming your current battery switch is a 1-2-both-off type switch? if so, might be a good time to switch to a dual circuit house/start battery setup with a DVSR or ASR.
I fried a couple of connext screens using a 1-2-both-off switch and suspect it was the cause.
One of the main problems with a 1, 2, 1&2 is whether or not they are a make then break set up. If they are not a make then break set up, and you switch the batteries when the engine is running, there is high likelyhood that you will fry your rectifier / regulators… you also get the voltage transients from engine starts to your electronics by not having a dedicated start battery.. that is where the two battery BEP switch that comes stock on the two battery Yamaha boats is an advantage.
New switch is good to go. Infinitely smaller than the perko its a blue sea 6007 the old mounting screws are too short for the new housing body so the last thing is getting some longer screws today and mounting it. Glad of the 3 boats I've owned this fix cost me roughly 50 between the switch and some new fuses.
Just be sure when going from 1 to 2 to go thru 1+2 and not thru off. Good chance for a voltage spike and a fried connext screen.
You probably don’t want to hear this, but I would strongly think about changing that out with a dual circuit switch (blue seas 6011 with ACR) or the BEP cluster with DVSR.
Also had a bad lead went and replaced the terminal got to the good wire and recrimped it.
Will order the dvsr with the noco2 thanks!
