YamahaCC
- MA
- SR
I have been out a number of times this year and recently have noticed oil in the bilge, center area, not much but enough to see when mixed with a bit of water dripping down from kids walking over the compartment and dripping in.
I bought a telescoping mirror w/a light on a hinge and can see oil weeping out from the starboard engine oil pan. It does not look to be coming from the oil filter, was hoping that might have been a hair bit loose but not the case. The port engine is fine with no oil under the pan. I can not pin point the leak area and it seem to collect on the bolt heads. Oil level is perfect within spec.
Is this a common issue? How concerned should I be? This is the 4th year with the boat, no issues prior to this. It has just under 200 hours on it. '06 SR210.
