biglar155
- Fredonia, WI
- SX
Oh man. Yeah, that's the problem.
Have you tried jumping the starter with a screw driver to see if it runs?
From the pics earlier, it looks like you need to replace the positive cable as well, it probably doesn't have enough good wire left to supply enough power to the starter . Or it may have burnt the "black box" out when it was shorting out on the shaft.Ok here's the latest.
I removed the ground cable completely. It's well over half worn out and I can replace it easily.
I disconnected the positive cable from the black box, used a jump pack and grounded it to the engine. I touched the positive to the loose end of the positive and the starter turned over... not strong, but there were sparks and the booster wasn't fully charged.
I then reconnected the positive to the black box, hooked up a jumper cable from the battery negative terminal to the engine and tried that. The solenoid only clicked.
You're not far off @buckbuck. The old car starters DID have the solenoid ON the starter. The part that throws the starter shaft into the ring gear is called the bendix. The reason for a solenoid is to isolate the low current circuit from your ignition switch from the high current circuit from your battery to your starter. You'll notice the wires going to your ignition switch are very thin for low current but the wire going to your starter is very thick for high current.Help me understand this. Is the solenoid physically on the starter? The device that throws the starter shaft into the ring gear so it turns the engine?
Don't run with that ratty wiring. You have been lucky that your boat has not caught fire yet. Best not to push your luck. If a fire starts in there I doubt you would have much choice but swim for it.
