OK, it seems like this should be easy, but.....
vikingknut
On my AR250 (2023), how do you remove the battery switch cover for the house battery to install a new electronic device (amp)? I thought it should be easy, but I am missing something (and it was getting too dark to look further).
adrianp89
Tampa Bay, FL
252SE
Should be screws holding the entire thing in.
Weeb
Denver NC 28037
The DVSR is bolted. There is nuts on the other side. It took me a bit to figure this out.
vikingknut
Mine is screws. Perhaps they are saving money where they can.
Weeb
Denver NC 28037
In order to add something you have to take the whole unit off which should be bolts.
Weeb
Denver NC 28037
The bolts have Phillips heads also
vikingknut
What year is your boat? I removed it, added my amp's positive connection and put it back. However, it was definitely just screws and not bolts with nuts.
lazergeek
South Florida
You have to remove all the screws, it comes off as a single piece. I recommend adding a buss bar in the battery compartment so you don't have to remove every time you add something
Weeb
Denver NC 28037
I have a 2017 ar240. I assumed they used the same dvsr in all the boats. But you know what happens when you assume. 😀
