Inthrustwetrust
- Destin FL
Welp first outting of the year, stbd motor started and cut out after a few seconds. Did this a few times and then ran fine. About 10 minutes later I git some weird vibrations thinking it was cavitation, moving the throttles a bit stopped the vibration, stbd was producing about 800rpm less than port at wide open, which is weird. 10 minutes after that I got a overheat on the stbd and shut it down. Impeller and shaft looked/felt clear. Currently limping home on 1 motor. What’s the fastest you can go 1 motor? I’m limping at 5 mph, it’s painfully slow, no tow valves installed
looks like there is some black rubber shavings where the drive shaft from the motor goes into the hull. 2020 AR240, seems like a shouldn’t be having this issue on a boat with 70 hours.
