Beachbummer
- Houston TX
- SX
So I pulled the pumps and the impellers need some work...but the shaft spins freely and feels pretty solid with no noise or rubbing.
I'm hesitant to take the cone off, since it appears to be well sealed, and has been for 10 years. If I peek, I can add new grease, but I run the risk of water intrusion if I don't seal it as well as the factory did (Or last guy, who know who last had it open)
The pump is making some noise while on the boat, when run dry, and the noise is from the pump, because I started the boat with no pump and the noise is gone... but the noise is not present when spinning by hand, and the whole mechanism feels solid and tight (so, where is the noise coming from? who knows.)
Crack it open? or Not?
Thanks!
Thanks!
