Babin Farms
- Lower Alabama
Any here have a plasma cutter at home? What do you have and what do/don't you like about it? I'm looking at a budget one for when I build my new wood boiler but other than that is not going to get used a lot. From the budget/homeowner ones I've been looking at I think that a 50A model would suit my needs(cut up to 1/2") I have a Hypertherm Powermax 45XP at work and love it but I'm not about to spend anywhere near that much $$ for one at home that'll hardly get used other than the boiler project. Thoughts?
Here is one that I'm considering
www.amicoelectric.com
![www.amicoelectric.com](https://i0.wp.com/www.amicoelectric.com/wp-content/uploads/2021/03/CUT-50-101.jpg?fit=800%2C800&ssl=1)
CUT-50, 50 Amp Professional Air Plasma Cutter, IGBT Inverter System, 3/4 inch Clean Cut. 100~250V Wide Voltage Machine
CUT-50 is a newly designed with the meter and adjustment attached to the front of the machine and the filter is located inside the machine. The new and improved model makes it more convenient and e…
![www.amicoelectric.com](https://i0.wp.com/www.amicoelectric.com/wp-content/uploads/2021/03/cropped-AE-Logo-500-1.png?fit=32%2C32&ssl=1)
