96Pirate
- Wake Forest, NC 27587
I can now say that the amp makes a huge improvement. I am very happy with my setup. Just need to readjust the zone setup.
Here is my setup....
Wet sounds HT-4 with 6 Polk MM651UM. The 4 in cabins are connected to the amp using all 4 channels at 4ohms and 110w. The 2 transom speakers are connected to the Fusion HU at 28w per. My cabins are seperate zone from transom. Currently, cabins are zone 3 and transoms are zones 1&2 combined. I will be switching this to cabins zone 1, transoms zone 2 and turn off zone 3. Just a wiring mistake not understanding how the zones can be setup. You can certainly hear the difference between the cabins and the transoms. In loudness as well as sound quality. Much fuller and cleaner sound. I have the gain set almost 1/2 dial and can listen to clean music at cruise at less than 1/2 volume with absolutely no distortion that I can hear. I used some cheapo RCA cables I had lying around with the intent of replacing with better but not sure how much more it can be improved....at least for my ears. I bumped up the bass about 1/4 turn.
Post what settings you end up using.
