Possible Project to smooth and coat jet pumps
@Jim Robeson, what would you recommend as a long lasting, sandable product to use on the jet pump? I would like to reseal mine then sand the sealant flush. Thanks
Jim Robeson
Springfield, Missouri
@Bruce ... can you tell me what kind of metal you think you pump is made from. I'm guessing aluminum?? Can you also tell me a little bit more of what you're trying to seal. I'm thinking right now that this sounds like a job for a two part product.
I believe the jet pumps in our boats are constructed from aluminum and fiberglass. I want to fill the seams where the aluminum and fiberglass comes together.
Jim Robeson
Any chance you could snap a picture of the area?? And does it need to be something for structural purposes or just filling in a gap?? Sorry for all the questions.
Sure, here is a picture from behind.
It is not structural, just the seal between the parts to reduce cavitation. I would like to experiment with smoothing the pump housing as much as possible then applying a layer of pump paint.
This photo is a "blueprinted" pump
Jim Robeson
@Bruce ... I will talk to some of our engineers and give you an idea on what to use. Most of our seam sealers/sealants are on the flexible side so that wouldn't work for sanding purposes. But we do have several two part products that get hard enough to sand/tap/drill etc... Do you care what color?? Some of our stuff I'm thinking about is black and gets very hard. We do have some gray material and even green.
Mainah
Chapin, SC
@Bruce - Why not just use gel coat for any small gaps that need filled? It is a sandable epoxy. Of course it will crack instead of flex but I don't know of a product that is both flexible and sandable beside plastic. If you must have flexible you could consider using ski base repair Ptex but I am not sure how well that would hold up.
Jim Robeson
@Jim Robeson, thank you I appreciate all your advice and offer to help.
I see the application is metal bonding. Do you think it will adhere to the fiberglass as well?
Also do you know if 3M offers anything similar to the Belzona 1341? I am going to contact Belzona about applicability but expect to spend around $300 if I use that product.
I just noticed these pictures in the Belzona marketing
Jet pump with cavitation wear
Belzona coated tube
Bill D
Prairieville, LA
Watching. :nailbiting:
It looks like Polymeric may be the industry term for these coatings and ScotchKote may be 3Ms similar product line.
Bruce I had to Reseal a pump a few years ago. Started with rtv silicone which worked for a few weeks before failing. Tried 3m 5200 but didn't seal it properly so I had cavitation. Finally i replaced the 5200 with 4200 and as far as I know it is still in place and working fine. At least it was two or three years afterwards and the last time I spoke with the boat's new owner was about two years ago now. 5200 is too strong and took forever to remove. I used a razor blade to smooth out the adhesive transitions and a dremel to remove the old material.
KXCam22
Kamloops BC
Bruce,
When I filled mine I used 5200 and since it is not sandable, I smoothed it while wet with laquer thinner. This worked well. The thinner would probably work with any similar sealer/filler. There were a few spots that I could have used a die grinder but the filler did a good job there as well. Cam.
Chip F.
Schuylkill Haven, PA
We use Belzona products a lot mostly 1311. Great stuff for fixing things around a power plant. Recently used it to repair a cut flange on the discharge of a boiler feed pump warm up line. Will have to keep this in mind when I do an inspection, I only have 30 hrs on the boat now. Doesn't look like it would take much.
@Chip F., I am having difficulty finding Belzona 1341. Do you know if your supplier sells it? My thinking is that I might use 2/3rds of the $350 500 gram package on one coat of the pumps.
Perhaps @Jim Robeson will find that one of the 3M Scothkote products would be perfect for us.
Chip F.
I will find out today for you.
Chip F.
Repair Technology
856-687-2225
500 gram kit =$241.00
Thanks @Chip F., I really appreciate it!
