- SF Bay Area
- Limited S
Like many others have stated, your impellers are shot. The leading edges are dull and or rough. That pitting is caused by cavitation, I was told it is called cavitational deterioration. I just replaced the stock units in my boat with some custom pitched solas units. It takes off better / feels like it has more grip and my top speed improved by about a mile per hour (the latter is not what I expected). It was not cheap, roughly $800 for the parts, I've seen them for less than $300 each but they won't be custom pitched.
If you are on a budget check out impros in scal. They will refurb your stock units for less than $100 each but as you can imagine they are busy this time of year so I would call to ask about the bench time before Id send them there.
http://impros.com/store/index.php/services/impeller-repair.html
If you need replacements now see if anyone here is willing to sell you their stock units. I'd sell you mine cheap but we have different boats. Alternatively you can go to places like sbt or island racing for rebuilt stock or after market units. I think Carl at island racing recommends two different solas impellers (not custom pitched) to improve performance. I've also read that the engines go out of synch by a few hundred Rpms as a result of using this setup but I think this can be corrected by varying the throttles or adjusting the throttle cable lengths.
My last bit of advice on this it to have a pwc shop remove take the impellers off the shaft. It will take them less than 15 minutes and you won't have to buy any tools that may only be used one time. I found a crescent wrench big enough to fit on the stock impellers at pepboys. The solas impellers need an even bigger wrench.
Good luck.
Good luck.
