- Daytona Beach Florida
- SX
Glad to know you can get the grease plus oil bath option all should be ok
if you asking about the OEM grease, yes - that 8oz bottle is more than enough for two pumps.One bottle enough for both pumps? Going to tackle this soon.
Do you meant the newer skis with TR-1s?The rental guys are saying the newer pumps in the boats with TR1s don't last as long.
Do you mix the Maxima into a slurry with synthetic gear oil? Any idea on how much grease to gear oil?Over the years I've used both plain old wheel bearing grease and the method of Amsoil synthetic grease mixed into a slurry with synthetic gear oil. They work. But lately switched to Maxima waterproof grease on the advice of a few folks at greenhulk.net. Seems to be working fine and easy to get.
Amazon.com: Maxima 80916 Waterproof Grease - 16 oz. Bottle : Automotive
When rebuilding a pump always use OEM parts including seals, bearings, and the pump cone o-ring. Don't use aftermarket parts as they are not always manufactured to the same specs. Spend the extra money for OEM.
-Greg
One of the MAIN reasons that it is important to use a grease that FLOWS back to the bearings. OEM YAMAHA PUMP GREASE ( that hard to find Epnoc 0 ) doesnt cut it! NOWHERE near "liquidy" enough.
When doing an impeller job or something that requires pump removal, other than a pump rebuild, we will remove the pump cone, DISPOSE of the OEM grease, and refill the cone with our LIQUID PUMP GREASE. in order to "thin out" the OEM stuff a bit.
Do a test for yourself. Lay the cone with the OEM stuff on the bench. Come back in an hour. guaranteed it will still be in the cone. If it is still in the cone it isnt flowing to your bearings.
some people may like a nicely lubricated cone.
